TwinTurbo.NET: Nissan 300ZX forum - Hi, so many things.... particually with mods..
Subject Hi, so many things.... particually with mods..
Posted by Medallion Man on June 29, 2013 at 11:00 AM
  This message has been viewed 461 times.
In Reply To 5-Speed Swap Done, idle issues?!?! posted by Drunkpunk082 on June 29, 2013 at 09:55 AM
Message I'd start with the basics..
do a full PM, check and clean everything, connectors (CAS, MAS, PTU, TPS, injectors...), filters, plugs... blah, blah...
run some ecu diagnostics to rule out any issues there.(best with software as that will show a lot more.. i.e. values)
check timing with a timing light.
do a full vac / boost leak test.
check that the ecu temp sender unit is working OK.
see where that puts you...
